utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
DexterJB
Nov 16, 2015NETGEAR Moderator
Hi utschy,
We apologize for the inconvenience that this has caused you. Rest assured, we are working on a fix. Just to make sure, you may use the download link below for the previous version (2.4.12) of the NETGEAR Genie program.
http://files.netgear-support.com/go/?a=d&i=cEJUI5BJSJ
Dexter
Community Team
truthreigns
Dec 30, 2015Aspirant
There is a blank page at this link
- DexterJBDec 30, 2015NETGEAR Moderator
Hi truthreigns,
Please try using another browser or computer. If that does not work, you can use the alternative download link below.
http://files.netgear-support.com/go/?a=d&i=BhR0tfRuDa
Dexter
Community Team
