utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
DexterJB
Jan 27, 2016NETGEAR Moderator
Hi @Fastercat,
If your computer is using Windows 10 and is getting an error message, you may follow the steps below.
1. Uninstall the NETGEAR Genie program from the computer/device.
2. Download the previous version (2.4.12) of the NETGEAR Genie.
Download link:
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
3. Install the program and check if it functions correctly.
4. Locate the drivers folder under C:\Program Files\NETGEAR Genie\bin and copy it to the desktop.
5. Download and install the latest version of NETGEAR Genie again using the download link below.
http://netgear.com/home/discover/apps/genie/aspx
6. Look for the same folder under the same location and delete the folder.
7. Replace the folder with the folder that you pasted on the desktop from the working version of NETGEAR Genie.
8. Close the NETGEAR Genie program through the system tray.
9. Re-open the NETGEAR Genie program and check if it works.
Dexter
Community Team
Fastercat
Jan 28, 2016Aspirant
That link doesnt work, it says not responding, need to close progam, and yes i am running windows 10 on my hp spectre i7
- DexterJBJan 30, 2016NETGEAR Moderator
Hi @Fastercat,
Here is another link for the previous version (2.4.12) of the NETGEAR Genie.
http://files.netgear-support.com/go/?a=d&i=1tUHs7pm4F
Dexter
Community Team
