utschy
Nov 15, 2015Initiate
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360. It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly. I uninstalled the ...
VietVetF4Drvr
Apr 02, 2016Aspirant
Upgraded from Windows 8.1 and the Genie continues to work just fine. Now on the Windows 10 Preview version, nothing from Netgear works. None of the adapter software genies.
DexterJB
Apr 05, 2016NETGEAR Moderator
Hi @VietVetF4Drvr,
1. Have you tried uninstalling and re-installing the drivers for the adapter?
2. Device drivers are tested to work on stable/public builds and not on preview/insider builds.
Dexter
Community Team
