blueboy320
Nov 10, 2012Follower
Netgear Genie windows 8
I'm running network Genie 2.2.27.1 WNDR4500 V1.0.1.20 However network Genie does not appear to be compatible with windows 8, it says the internet is off line but, it appears to work normally. Does ...
Aurora420
Nov 10, 2012Aspirant
No problems with Genie (same version) here on Win8, using WNDA4100 adapter. Does the "Internet Offline" only appear for a short time, or does it always say that for you?
http://i.imgur.com/lBxK0.png
http://i.imgur.com/CLRTD.png
You may or may not have to enable .Net Framework 3.5 (I already had it enabled before testing this for you, due to an issue with installing inSSIDer)
Here’s how to enable it:
1. Copy sxs folder from your install ISO to the root of C: drive (not sure why this can’t be done with the contents of Winsxs folder... maybe it can?)
2. Run the following command from an elevated command prompt (CMD Admin):
dism /online /enable-feature /featurename:NetFx3 /All /Source:C:\sxs /LimitAccess
Main reference:
http://msdn.microsoft.com/en-us/library/hh506443.aspx
Secondary (note - incorrect syntax in their suggested command! Missing : between source and C)
http://blogs.technet.com/b/aviraj/archive/2012/08/04/windows-8-enable-net-framework-3-5-includes-net-2-0-and-3-0-i-e-netfx3-feature-in-online-amp-offline-mode.aspx
I would uninstall genie, then reboot and enable .Net 3.5 as shown above, then reboot and install Genie again and see if that helps.
Main reference:
