Praezin
Dec 09, 2016Aspirant
Netgear Genie Windows won't run
I have downloaded and installed and tried to run Genie on my Windows 10 machine, but alas nothing happens. I get runtime error and it closes the program. Newer Windows 10 machine, completely uptodate...
Praezin
Dec 10, 2016Aspirant
Thank you for the suggestion. I have my standard login ID which is set as a standard user (for security). I tried to run Genie with the 'Run as Administrator' option on right-click...low and behold it works! Still aggravating that I have to do that.
EDIT: I downloaded the latest version straight from netgear site and yet, when I get to the router settings page, there is no drop down for remote like in the video.
michaelkenward
Dec 10, 2016Guru - Experienced User
Hmm. Gets even more confusing.
Your message prompted me to upgrade to the newer Windows genie.
That seems to work. Today at least.
