ibear60's avatar
ibear60
Netgear Genie with a wndrmac router
The Network Genie is asking me to input a 5 or 13 digit password to access the wireless network but the passwork is only 12 digits and the router will not accept it.  What's up with that?
  • Thanks Dexter...  I'm connecting an older PC notebook to my wifi.  I'm able to connect with an ethernet cable to the back of the router but when I use the Netgear Genie to help with a wireless connection it asks for a 5 or 13 digit password.  I verified the password and its only 12 digits....the Genie won't take it.  I made it work by setting up a "guest" network for 24 hrs but I still can't connect directly with the wifi channel.     I'll try to connect with the User Interface next.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ibear60,
    1. Try accessing the router UI itself to confirm the wireless password instead.
    2. What device are you trying to connect?
    Dexter
    Community Team
    • ibear60's avatar
      ibear60
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi ibear60,
        Thank you for the update. I would recommend accessing the router UI itself and make sure you have the correct WiFi password and router admin password.
        Dexter
        Community Team
