Royalman
Jan 04, 2016Aspirant
Netgear Genie with XAV 1301 and Windows 10
I use Netgear Genie for just one reason. Checking the speed of my Powerline Adapters. I currently have 3 off XAV1301 and 1 off XAVN2001. Unfortunately there is some history to this. There was once a...
DexterJB
Jan 04, 2016NETGEAR Moderator
Hi Royalman,
1. What version of NETGEAR Genie did you previously had with your Vista computer?
2. What was the link rate speed did it show you before on your powerline adapters?
Dexter
Community Team
- RoyalmanJan 05, 2016Aspirant
Hi Dexter,
My Download speeds are consistently in the range 185Mbs to 195Mbs. And the uploads were of a similar order.
I don't know what version of Genie was running on my old Vista PC as it died suddenly and wasn't worth repairing. I have found the install file from my backup and it is was just called NETGEARGenie-install. Later versions of Netgear Genie seem to have the version number embedded in the name of the install file you download. It's a shame Netgear didn't do this on earlier versions.
As it happens my preferred solution would be to use the Powerline Utility. Looking last night I see that is now at version 3.1.0.4. The version I couldn't get going with both V1 and V2 of the XAV1301 was 2.2.27.1. Let me try that latest version of the Powerline Utility as Netgear are saying it is Windows 10 compatible.
Do you know if Netgear will continue to fix bugs in the Powerline Utility? Or has any ongoing development ceased?
Hi Dexter,
After reinstalling Netgear Genie it does recognize XAV1301 V1 and V2. However the V2 upload speed shows as between 25 and 30 Mbps, while the V1 still shows consistent upload speeds of exactly 10Mbps. All the download speeds are in excess of 150Mbps.
My combination of Power Adapters in this final configuration were:
1 off XAVN 2001 V2
3 off XAV 1301 V1
1 off XAV 1301 V2
Thanks
Trefor
- DexterJBJan 05, 2016NETGEAR Moderator
Hi Royalman,
Thank you for the updates. Can you please provide screenshots of the utility and NETGEAR Genie program showing the speeds?
Dexter
Community Team
- RoyalmanJan 06, 2016Aspirant
Hello Dexter,
I read all the Help here on the message board, but I just couldn't work out how to insert an image into the Discussion Board. So I have emailed the sceenshot to you at community@netgear.com
