Royalman
Jan 04, 2016Aspirant
Netgear Genie with XAV 1301 and Windows 10
I use Netgear Genie for just one reason. Checking the speed of my Powerline Adapters. I currently have 3 off XAV1301 and 1 off XAVN2001. Unfortunately there is some history to this. There was once a...
Royalman
Jan 06, 2016Aspirant
Hello Dexter,
I read all the Help here on the message board, but I just couldn't work out how to insert an image into the Discussion Board. So I have emailed the sceenshot to you at community@netgear.com
DexterJB
Jan 06, 2016NETGEAR Moderator
Hi Royalman,
In the option to reply, there should be an option that indicates "Image". It will allow you to attach your screenshot files.
Dexter
Community Team
- RoyalmanJan 07, 2016Aspirant
Post deleted.
Hello Dexter,
I have now managed to upload the image. I have no idea why I couldn't do it before. Up to now I have written my post and then logged in. Possibly to insert an image you already need to be logged in. That seems to have been the only thing that was different when it worked.
- DexterJBJan 09, 2016NETGEAR Moderator
Hi @Royalman,
Thank you. Are the values consistent at 10Mbps whether there is network activity or not?
Dexter
Community Team
- RoyalmanJan 10, 2016Aspirant
Hello Dexter,
The 10 Mbps is constant. And independent of any network activity. Also I am on a metered broadband service. My monthly usage is about 20GB. And the vast majority of that is downloads (software updates, a few YouTube videos etc). My uploads are minimal; I do not participate in file-sharing or similar.
I am now convinced there is a bug in the Genie App. I had exactly the same problem on my old Windows Vista PC after upgrading Genie. In that case I solved the problem by going back to an earlier version of Genie. However that older version will not even install under Windows 10, so I am forced to use 2.4.12.
Thanks
