RoboGenie
Jan 15, 2016Initiate
Netgear Genie won't quit on Mac OS X
Unlike some people here, I had no trouble downbloading and installing Netgear Genie on my Mac system, first on an old iMac running OS X v10.6.8 and now on my new iMac running 10.11.2. Unfortunately t...
- Sep 26, 2016
All:
Here's what (sorta) worked for me, based on escalation at Netgear to "Bianca" who seemed to really know how to troubleshoot. The fix that worked for me was to open the Genie package and to add a leading "1" to the component "libGeniePlugin_MyMedia.dylib", making it "1libGeniePlugin_MyMedia.dylib". This disables the Media Center features of the router, which I don't use anyway. Now, CPU usage is at about 10% (still too high for a "monitor", but tolerable), and I no longer have to force quit.Jonathan
DexterJB
Jan 16, 2016NETGEAR Moderator
Hi @RoboGenie,
Thank you for your feedback. Rest assured, we are always working on improving the features and user experience for the program.
Dexter
Community Team
RSM52
Sep 25, 2016Tutor
It is noted that you were working on the problem of having to force quit out of Network Genie as of last January, yet the problerm still persists. When is this issue going to be fixed?
- BackIntoBottleSep 26, 2016Tutor
All:
- SeaSep 26, 2016Guide
Thanks for posting that. I received similar instructions several months ago and was looking to post it when another frustrated Mac user posted to this string. Personally, I don't find the "added value" of Genie - as opposed to querying the router directly from the browser - not worth the trouble.
whoops...one too many negatives in there, but you get my point.
- RSM52Sep 27, 2016Tutor
Thanks for the workaround!
- Bharathy84Sep 28, 2016Aspirant
That did the magic for me. Thanks a ton !!!
