Thisisme118
May 09, 2017Aspirant
Netgear Genie
I have a windows 10 computer with a R8000 router. I am trying to logon to it from Genie, but it states "Login Failed. The router Response timed out". However, I can logon with the same user name a...
michaelkenward
May 10, 2017Guru - Experienced User
Try feeding the router's IP address into the (desktop?) genie.
The genie is a flaky beast at the best of times.
Thisisme118
May 10, 2017Aspirant
I have checked the box for router IP address and that did not work. I did power cycle the router and that worked. ONCE! I can not longer get into the router again.
- michaelkenwardMay 10, 2017Guru - Experienced User
You can find the IP address by using a small Windows thingy called ipconfig from a Command prompt and looking for the default gateway.
- Thisisme118May 10, 2017Aspirant
I am not sure what you are trying to tell me what to do. I am familair with IPconfig, but only getting my IP address. Is there command line switches you want me to use?
Sorry just checked again. The default gateway is 192.168.1.1.
