velocci
Jan 12, 2012Novice
Netgear Genie
Hi all, I installed the netgear genie app. I notice in the Internet tab, if you look at the bottom you see a slider that goes upto 20Mbps and button for "High Traffic Threshold. What are these for ex...
croisan
Jan 15, 2012Aspirant
If you search Google for Netgear Genie, you will find the software download site. There is also a link for the user manual. This will get you there a little faster.
http://www.netgear.com/landing/en-us/netgear-genie.aspx
NeedHelpToo
Nov 18, 2015Aspirant
FYI the manual doesn't tell you what the "high threshold" checkbox does.... does anyone know?
- DexterJBNov 22, 2015NETGEAR Moderator
Hi NeedHelpToo,
The "High Traffic Threshold" check box will enable the NETGEAR Genie to monitor and notify you whenever it reaches the slider value of Internet traffic that you have set for the upload and/or download.
Dexter
Community Team
