spollard101
Mar 08, 2022Tutor
Netgear Nighthawk App keeps saying Logon timed out
Hello! I hope someone is able to help me out - because this is so unbelieveably frustrating. For starters - using: Netgear Modem CM500 Netgear Nightawk AC1750 Route R6700v3 ISP: Comcas...
Mar 08, 2022Guru - Experienced User
You download it from the support site (downloads--->view previous versions)
Then simply follow the manual update process but use the older firmware instead of the newer version.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
michaelkenward
Mar 15, 2022Guru - Experienced User
A new version of the Nighthawk app has just landed.
Maybe it fixes whatever was broken.
- logontimedoutSep 13, 2022Initiate
Current version of app (1.19.0.2392) does not fix the "logon timed out" issue. Nighthawk app is useless now.
Android 12 on Pixel 6pro.
- VaylgarNov 03, 2022AspirantI have been getting this the last couple weeks now on my old firmware , I upgraded my firmware to see if it resolved this and it did not , I'm also now having a serious issue where my router is also throttling my connection speed to my isp I can test on thier router my nighthawk is rj45 into and their speed to me is approx 92 mbs if I go through my nighthawk all of a sudden I'm only able to get 6 mega per sec bandwidth and my QoS is not enabled. I dont understand what could have changed on it's own! I am rusty but I'm a microsoft certified systems engineer and been a network administrator for 5 years and been doing my own networks longer. This is a serious problem for me!!
- michaelkenwardNov 03, 2022Guru - Experienced User
Vaylgar wrote:
I have been getting this the last couple weeks now on my old firmware , I upgraded my firmware to see if it resolved this and it did not ,It seems to be related to the app rather than anything else.
Vaylgar wrote:
I'm also now having a serious issue where my router is also throttling my connection speed to my ispHard to see how these two things can be related.
You might want to start a fresh conversation to try to get to the bottom of that one.
