spollard101
Mar 08, 2022Tutor
Netgear Nighthawk App keeps saying Logon timed out
Hello! I hope someone is able to help me out - because this is so unbelieveably frustrating. For starters - using: Netgear Modem CM500 Netgear Nightawk AC1750 Route R6700v3 ISP: Comcas...
michaelkenward
Mar 15, 2022Guru - Experienced User
A new version of the Nighthawk app has just landed.
Maybe it fixes whatever was broken.
logontimedout
Sep 12, 2022Initiate
Current version of app (1.19.0.2392) does not fix the "logon timed out" issue. Nighthawk app is useless now.
Android 12 on Pixel 6pro.
- VaylgarNov 03, 2022AspirantI have been getting this the last couple weeks now on my old firmware , I upgraded my firmware to see if it resolved this and it did not , I'm also now having a serious issue where my router is also throttling my connection speed to my isp I can test on thier router my nighthawk is rj45 into and their speed to me is approx 92 mbs if I go through my nighthawk all of a sudden I'm only able to get 6 mega per sec bandwidth and my QoS is not enabled. I dont understand what could have changed on it's own! I am rusty but I'm a microsoft certified systems engineer and been a network administrator for 5 years and been doing my own networks longer. This is a serious problem for me!!
- michaelkenwardNov 03, 2022Guru - Experienced User
Vaylgar wrote:
I have been getting this the last couple weeks now on my old firmware , I upgraded my firmware to see if it resolved this and it did not ,It seems to be related to the app rather than anything else.
Vaylgar wrote:
I'm also now having a serious issue where my router is also throttling my connection speed to my ispHard to see how these two things can be related.
You might want to start a fresh conversation to try to get to the bottom of that one.
- jgottbrathNov 03, 2022Tutor
Well fact no one from Netgear has even bothered to respond and all updates since my original message did not fix issue. I suspect Netgear does not care... probably will not buy Netgear again. Anyone have a good suggestion for other routers?
