spollard101
Mar 08, 2022Tutor
Netgear Nighthawk App keeps saying Logon timed out
Hello! I hope someone is able to help me out - because this is so unbelieveably frustrating. For starters - using: Netgear Modem CM500 Netgear Nightawk AC1750 Route R6700v3 ISP: Comcas...
jgottbrath
Nov 04, 2022Tutor
Yes, I read the issue is app only. Point is that if Netgear is not going support the app or appearing to act interested in fixing when known issue why would I want to continue to use their product. I can log directly into it, but it is an old nighthawk. It is getting time to replace, so debating which brand to switch if Netgear is not interested in fixing issues customers are having.
Your probably right I should create my own. Not sure if I want to exert that much effort at this point.
michaelkenward
Nov 05, 2022Guru - Experienced User
Up to you, but the first bit is incorrect.
Netgear is "appearing to act interested" albeit a bit too slowly for most people.
