spollard101
Mar 08, 2022Tutor
Netgear Nighthawk App keeps saying Logon timed out
Hello! I hope someone is able to help me out - because this is so unbelieveably frustrating. For starters - using: Netgear Modem CM500 Netgear Nightawk AC1750 Route R6700v3 ISP: Comcas...
Sczzi
Nov 13, 2022Aspirant
Netgear I just bought a brand new router been literally putting my hair out trying to get the router set up for 3 days. every night after work I can't log out of my account. when I try to log on it says "login time out please try again " been trying for 3. days this is unbelievable I am unbelievably mad at this thing most frustrating in ever had with the internet. now I'm stuck with this garbage router setup I have no receipt to return this $179.00 router. AC2600 router model number is r7450 and now out of frustration, it is in pieces what a total nightmare the whole thing was. I can't turn off an unknown device connected to my wifi
- michaelkenwardNov 14, 2022Guru - Experienced User
Sczzi wrote:
Netgear I just bought a brand new router been literally putting my hair out trying to get the router set up for 3 days. every night after work I can't log out of my account. when I try to log on it says "login time out please try again " ...
That is because you are trying to set up the router using a mobile app. Netgear tries to force everyone to do that but it it is not necessary.
How do I install my NETGEAR router using the router web interface? | Answer | NETGEAR Support
That has been the recommended method for most of the life of Netgear's routers.
For many people it remains the best way to set up a router.
- RayjensenNov 23, 2022AspirantI have the same problem with login timeout on the app, but I alsoe have the problem when I try to login with My homeassistant system. It startet at the same time...
My firmvare is: V1.0.11.136_10.2.120
I tryed a factory reset, and after that it worked for 2 days, and now I am back again, not able to login..
Could it be a memory problem??- michaelkenwardNov 24, 2022Guru - Experienced User
Rayjensen wrote:
I have the same problem with login timeout on the app, ....Possibly, but this discussion is so old that it is impossible to know which bits are relevant your problems.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
