picketma
Jan 17, 2024Tutor
Netgear Nighthawk App Login Timed Out
I have the R6700 v3 with firmware V1.0.4.128_10.0.104 attached to the NG CM1000, running Armor on the router and circle. I have not had any issue for a long time, so have not needed to log into the N...
- Mar 21, 2024I know it was mentioned that turning off private relay didn’t work for you, but for anyone else who might stumble across this, turning off private relay did fix the issue for me immediately. I was quite surprised that did the trick.
I don’t really understand why that even worked. It’s two devices talking on a local network. Either apple’s private relay is doing things you wouldn’t expect, or netgear’s app is. Still, I’m glad I read this post which prompted me to at least try it. This was driving me nuts for months
michaelkenward
Jan 17, 2024Guru - Experienced User
picketma wrote:
Now I'm getting notifications on my iphone (XR, running ios 17.2.1, just updated hoping that would fix the issue) that Armor is blocking fraud attempts.
I'd start with this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
- picketmaJan 17, 2024Tutor
Thank you. I turned off the private wi-fi addresses years ago because it was loading an enormous number of "devices" into my circle account. The private relay on my iCloud is off as well. Thought my VPN might be blocking it for some odd reason, but that is not it. I went to log in and started shaking my phone as soon as I hit "sign in" and thankfully the "report a bug" screen came up. I have reported the issue, hopefully they can get this glitch fixed.
- DrewkermanzMar 21, 2024InitiateI know it was mentioned that turning off private relay didn’t work for you, but for anyone else who might stumble across this, turning off private relay did fix the issue for me immediately. I was quite surprised that did the trick.
