picketma's avatar
Jan 17, 2024
Netgear Nighthawk App Login Timed Out
I have the R6700 v3 with firmware V1.0.4.128_10.0.104 attached to the NG CM1000, running Armor on the router and circle. I have not had any issue for a long time, so have not needed to log into the N...
  • Drewkermanz's avatar
    Drewkermanz
    Mar 21, 2024
    I know it was mentioned that turning off private relay didn’t work for you, but for anyone else who might stumble across this, turning off private relay did fix the issue for me immediately. I was quite surprised that did the trick.
    I don’t really understand why that even worked. It’s two devices talking on a local network. Either apple’s private relay is doing things you wouldn’t expect, or netgear’s app is. Still, I’m glad I read this post which prompted me to at least try it. This was driving me nuts for months
