AmesKay2021
Oct 24, 2021Aspirant
Netgear Nighthawk App on iPhone Device Manager is NOT working
Hello Issues #1. Device Manager device status does not sync with what I see on the log in page on my computer I click one of the devices to "pauce" on my app (on my iPhone), the webpage on the...
DarrenM
Oct 29, 2021Sr. NETGEAR Moderator
Hello AmesKay
We are aware of the issues with the device manager in the app and are working to fix this issue. You should be able to control the device manager via www.routerlogin.net until we are able to fix the issue.
Thanks
DarrenM
bulldog00
Nov 03, 2021Apprentice
Why not allow us to downgrade the firmware? There were not issues with the previous firmware available. I can manually downgrade, but it seems Netgear forces updates and there is no way to disable auto update with the MR80 router.
- FURRYe38Nov 03, 2021Guru - Experienced User
So you can't disable auto updates on MK systems? Nothing under Admin/Firmware updates?
Do you have a router in front of the MK system by chance?
- bulldog00Nov 03, 2021ApprenticeNope no option to disable auto updates in the MK series (no options in admin-firmware update). No router in front of the MR83 either.
