uglyangel
Oct 25, 2021Aspirant
Netgear Nighthawk App
Is it possible to have two Nighthawk routers on the app? I have one each at two different homes and would like to monitor both through the app but I could not figure out how to have both on the app. ...
DexterJB
Oct 27, 2021NETGEAR Moderator
Hi uglyangel, yes, it is possible. You'll just have to enable the Anywhere Access feature on both routers/homes. The link below may help out.
Dexter
Community Team
uglyangel
Oct 29, 2021Aspirant
Thank you for replying. I will have to try your solution next time I am at the other house. Unfortunately it is in another state. That is why I wanted to get both on the app so I could monitor them. I will let you know if it works.
Thanks.
- FURRYe38Nov 04, 2021Guru - Experienced User
Any progress on this?
Thanks.
- uglyangelNov 04, 2021Aspirant
I can not try a solution until I am in the same state as the router. As soon as I do try this a solution I will reply back.
Thanks.
