uglyangel
Oct 25, 2021Aspirant
Netgear Nighthawk App
Is it possible to have two Nighthawk routers on the app? I have one each at two different homes and would like to monitor both through the app but I could not figure out how to have both on the app. ...
uglyangel
Oct 29, 2021Aspirant
Thank you for replying. I will have to try your solution next time I am at the other house. Unfortunately it is in another state. That is why I wanted to get both on the app so I could monitor them. I will let you know if it works.
Thanks.
Nov 04, 2021Guru - Experienced User
Any progress on this?
Thanks.
- uglyangelNov 04, 2021Aspirant
I can not try a solution until I am in the same state as the router. As soon as I do try this a solution I will reply back.
Thanks.
