sidkat
Feb 23, 2023Aspirant
NEtgear NightHawk App
Since the update from 2/23/23 when I re-downloaded my NightHawk app the only thing it shows is my CAX30 is connected locally. I can't check my internet speed, metered connections or what devices are ...
Feb 24, 2023Guru - Experienced User
If v2.x please use a wired PC and web browser to downgrade the modem to v1.4x FW
sidkat wrote:
Since the update from 2/23/23 when I re-downloaded my NightHawk app the only thing it shows is my CAX30 is connected locally. I can't check my internet speed, metered connections or what devices are at 2.4 or 5Gh. Is there someway to fix this?
