EJC2's avatar
EJC2
Initiate
Oct 15, 2017
Netgear NightHawk R7500 x4 GenieAFX.dll error with updated firmware
I keep getting 6 popups on my screen that I have to constantly remove. I reads as follows:
C:\Programfiles\NETGEAR\ReadyShare Vault\GenieAFX.dll is either not designed to run on Windows or it contains an error.
My backup program was working fine until the errors started. I tried to uninstall Netgear Genie and reinstall but it still will not work.
Any suggestions would be appreciated.
  • Have you added or updated any of the programs on the computer sounds like a link was changed or removed on the os program Windows has doing updates almost every month.
    • EJC2's avatar
      EJC2
      Initiate
      I have not done any updates. When I posted as updated firmware I meant that I had the lastest update installed. After not being able to get the program working and the need for it I found the Vault program on the Netgear website. I downloaded it and reinstalled and it now works. I found that the link through the router did not direct me to the download I needed. Thanks for the feedback.
