Manchek's avatar
Manchek
Initiate
Jan 06, 2021
Netgear Nighthawk R7960P
Anyone else having a problem logging into the R7960P router via the Android phone app since the last firmware update?
I can log into the router via IP address.  I have changed the router admin password as a test but the phone app login still does not work.  It timeouts with a message to try again or reboot the router.  The problem remains after rebooting the router.
Thanks for any info.
  • Fixed my own issue.  Cleared cache for the Nighthawk phone app and login works now.
    • MrRAZ's avatar
      MrRAZ
      Tried clearing mine worked but then booted me out of app again.
