redonaldson
Oct 27, 2022Aspirant
Netgear Nighthawk RAX120
I have three Nighthawk routers at different locations. Recently my ability to remotely access and perform management and rebooting stopped. Can anyone help with what I might do to regain that feature...
Oct 27, 2022Guru - Experienced User
What 3 routers do you have?
Is this thru the Nighthawk app?
- redonaldsonOct 27, 2022Aspirant
All three are RAX 120 Routers on 400 MBPS connections. All three worked great with Remote until a few weeks ago and something changed and cut Remote off on all three routers. I can access the router via the app when I am on that network. One is 35 mile from home and one is 15 miles from home - quite inconvenient when issues arise.
- FURRYe38Oct 27, 2022Guru - Experienced User
What version of the app are you using?
Is there a screen capture of what you see that you can post here?
Do you know if these 120s are v1s or v2s?- redonaldsonOct 27, 2022Aspirant
Yes - Anywhere access.
I cannot see the firmware version. The problem started with the last firm wear version update. I checked earlier this week and "Update Firmware" showed no newer version at this time.
2 are V1s and 1 is a V2
The app is the current one on Apple App Store
I am not at any of the locations of the routers now. Again two of these have worked flawlessly for 18 to 24 months(1 v1 and the v2) The other v1 I moved a year ago and it worked at the new location for the past 12 months.
The problem arose with the installation of the last firmware update.
- michaelkenwardOct 27, 2022Guru - Experienced User
That is not a reliable test.
There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the app or the browser interface.
The preferred option is a manual update.
Download the firmware from the support section and update it yourself
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual on updating the firmware.or
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
