redonaldson
Oct 27, 2022Aspirant
Netgear Nighthawk RAX120
I have three Nighthawk routers at different locations. Recently my ability to remotely access and perform management and rebooting stopped. Can anyone help with what I might do to regain that feature...
redonaldson
All three are RAX 120 Routers on 400 MBPS connections. All three worked great with Remote until a few weeks ago and something changed and cut Remote off on all three routers. I can access the router via the app when I am on that network. One is 35 mile from home and one is 15 miles from home - quite inconvenient when issues arise.
Oct 27, 2022Guru - Experienced User
Is this thru the Nighthawk app?
What version of the app are you using?
Is there a screen capture of what you see that you can post here?
Do you know if these 120s are v1s or v2s?
- redonaldsonOct 27, 2022Aspirant
Yes - Anywhere access.
