UJ
Mar 29, 2016Aspirant
Netgear R6400 router firmware v1.0.1.6_1.0.4 port forwarding not working
Hi, I am using Netgear R6400 router with Firmware V1.0.1.6_1.0.4. This router does not function with port forwarding at all. Any port that I setup has no effect. My old router just works fine. It se...
DexterJB
Apr 02, 2016NETGEAR Moderator
Hi @UJ,
1. Which ports are you trying to forward?
2. How are you testing if the ports are opened?
3. Have you tried resetting the router?
4. Have you tried re-flashing the firmware?
Dexter
Community Team
- UJApr 06, 2016Aspirant
Please see my answer next to each questions in bold letters.
1. Which ports are you trying to forward? *8088 (A port that I have used
for web server and worked fine with previous router)*
2. How are you testing if the ports are opened? *(1. with mobile app that
worked before 2. open port scanner web app from outside the home network)*
3. Have you tried resetting the router?* (Yes)*
4. Have you tried re-flashing the firmware? *(Yes, with the latest firmware
R6400 version 1.0.1.6_1.0.4)*
*Thanks*
UJ- DexterJBApr 09, 2016NETGEAR Moderator
Hi @UJ,
1. Have you tried forwarding other ports? If yes, do they work?
2. Have you tried bypassing the router to check if it still works straight from the modem?
3. Do you still have your previous router? If yes, does connecting it still work?
4. Has it ever worked with the R6400?
Dexter
Community Team
- UJApr 10, 2016Aspirant
My answers in Bold;
1. Have you tried forwarding other ports? If yes, do they work? Yes, I have tried different ports, none of them worked so far.
2. Have you tried bypassing the router to check if it still works straight from the modem? Yes, bypassing router R6400 worked fine. (Using my old router)
3. Do you still have your previous router? If yes, does connecting it still work? Yes, everything works fine when old router is connected
4. Has it ever worked with the R6400? No, not even when new R6400 is connected.
It seems, something is not right with R6400 model. Port forwarding can't be this problematic.
Thanks for looking into this matter.
