maneesh
Mar 31, 2017Aspirant
Netgear R700 : Parental control - Multiple schedule
My multiple schedule parental control is not working. I want to have no restriction from 6:45AM to 10:30AM and 1PM to 2:30PM. But its taking the default filtering level at all time. Appreciate your h...
- Apr 06, 2017
Hi maneesh,
1. Please try setting a different filtering level and check if the issue persists.
2. Are all devices affected?
3. You can also check the per device filtering. Steps are on the link below.
http://kb.netgear.com/app/answers/detail/a_id/29913
Dexter
Community Team
DexterJB
Apr 06, 2017NETGEAR Moderator
Hi maneesh,
Dexter
Community Team
- DexterJBApr 09, 2017NETGEAR Moderator
Hi maneesh,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- maneeshApr 22, 2017Aspirant
Hi Dexter,
Sorry for the late reply. I have tried different filtering level, but it always takes default one. My per device filtering is set to default unless i manually change throuh genie network map.
