TenaciousJ
Jan 02, 2021Follower
Netgear R8000 using Mac cannot get to Genie - help !
Can anyone help me? I need to get back to the Netgear Genie page. I have the R8000. I have changed all passwords, blocked users I don't recognize but some a**hole is still showing up and I can't seem to deny him/her access.
When I enter routerlogin.net it automatically assumes I want to change my password. I've done that twice. Either way it doesnt get me to the Netgear Genie page.
Any idea would be much appricated
1 Reply
What genie page is that?
It could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
If you are on a wired connection, you should be able to login to the browser graphical user interface (GUI) in the usual way.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
