Donl1000
Mar 23, 2016Follower
"Netgear router is not found or is not supported. Also, no IPv6 is enabled' Windows 10
Wireless works but no wired internet connection after Windows 10 installed. Up dated Genie and did the work around. Worked for a while on and off. now nothing????
petercloud29
May 11, 2016Aspirant
Configuring repeating settings:
- First, you need to connect your wireless router device which you wish to function as the repeater to the computer using the standard Ethernet cable.
- Then, login to the Netgear router by typing 192.168.1.254 ip address in to the address bar of your web browser. Then, press Enter.
- The login page of a router will be displayed on the screen. In the username text box, you have to enter the default username admin and a default password is password. When you have already changed your router device default password, then you have to enter your custom password and then hit Enter.
- In this step, you must have to click on the maintenance -> Router status.
- Note down a value of MAC address displayed on this status screen of your network router.
- Then, connect to a wireless network you wish to repeat.
- Once logged in to your Netgear router, you need to click on the wireless settings.
- Note down the values of 11N channel, Mode, SSID, security encryption key, and also security options fields.
- Click on the advanced and wireless repeating function.
- After that, click on the enable wireless repeating function and then wireless base station.
TheEther
May 11, 2016Guru
petercloud29 Did you mean to post in a different thread?
