Donl1000
Mar 23, 2016Follower
"Netgear router is not found or is not supported. Also, no IPv6 is enabled' Windows 10
Wireless works but no wired internet connection after Windows 10 installed. Up dated Genie and did the work around. Worked for a while on and off. now nothing????
Ekim1pch
May 23, 2017Aspirant
I'm having a similar problem with my WNDR4500v2. Don't know the firmware. No luck logging on with 198.168.1.1 and 198.168.1.0 routerlogin.net and routerlogin.com.
I've tried power cycle and resetting the router, and tried two delegate computers. I can ping the router on 198.168.1.1 and ping websites like google.com; the wifi is working and says it's connected to the internet but I can't access the internet nor log into the router.
I also tried PeterClouds methods with direct plugging Ethernet into the computer and typing the 198.168.1.245, and that's where the road ends. I loaded the newest firmware but I can't access the router to load it. Help me pls!
