homerouter
Mar 15, 2020Follower
Netgear Router R7900P
Hi,
The NightHawk app for Iphone is no longer working after Netgear Router R7900P updated Firmware Version
V1.4.1.50_1.3.10. Anyone knows how to resolve the problem Thanks
1 Reply
After you have determined that this really is the issue – hard to tell from the limited details you provide – you can roll back the firmware on your R7900P to a version that works.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation, and, if there are any, firmware versions and drivers for your hardware.Then check this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
