ricbret
Oct 20, 2018Guide
Netgear USB Control Center and Mac OS Mojave 10.14
Configuration:
Internet connection through Netgear Nighthawk r7000 A1900 Smart Wifi Router
USB connection from Brother HL-l2300D (no built-in networking) to Netgear AC1200 High Power 700mW Dual...
DexterJB
Oct 22, 2018NETGEAR Moderator
Hi ricbret,
Welcome to the community!
Please make sure you allow the installation of apps downloaded from the app store and identified developers.
Dexter
Community Team
- ricbretOct 22, 2018Guide
Yes, the "Allow apps downloaded from" option has "App Store and identified developers" selected. That is not the problem. See many other similar reports, although those are against High Siera, not Oasis.
- DexterJBOct 28, 2018NETGEAR Moderator
- DavidChenNov 11, 2018Aspirant
Hi Community Team,
My app has the same problem, R6400, Mac OS X 10.14, USB control center just doesn't work. I'd like to ask is there an update version of the app can be used?
Thanks.
- ricbretNov 11, 2018Guide
Yes, it's pretty obvious what's happened, all this level 1 support can be pretty tedious. It just needs to be QA'd to easily confirm there's a bug in this configuration (latest released USB Control Center build and Mac OSX 10.13 or 10.14.
The bug should be on the developer's plate by this point, but I have my doubts.
-Ric
