ricbret
Oct 21, 2018Guide
Netgear USB Control Center and Mac OS Mojave 10.14
Configuration:
Internet connection through Netgear Nighthawk r7000 A1900 Smart Wifi Router
USB connection from Brother HL-l2300D (no built-in networking) to Netgear AC1200 High Power 700mW Dual...
JeffStent
Jan 27, 2019Tutor
This issue has been on the list for months. When can we expect a resolution?
Also, when I download and install the print share software it fails repeatedly showing ' Installation incomplete'. I am not alone with that issue as well. C'mon guys - any progress to report?
- JeffStentFeb 01, 2019Tutor
Here is a great work-around for network printing until Netgear figures it out. Search internet for a 'shareware' program called HandyPrint. Works simply smooth with my Netgear R6400 router, Mac iOS 10.14 and Canon D530 printer.
- ricbretFeb 01, 2019Guide
So Jeff, will this will work with dumb printers that only have a USB interface that is plugged into a Netgear extender? Do you recommend the 5.0 version, or is the 3.15 version suitable for determining it's performance?
- JeffStentFeb 02, 2019Tutor
My printer is a dumb printer. I simply plug the USB printer cable into the rear, 2.0 USB port. I believe my Handy Print software is the most recent for iOS. That is version 5.2. Works like a charm. Just be prepared for a bit of delay before the printer starts. I use this for both my iPhone, and my wife’s iPhone. We each also print from iPads
I hope that helps!
