ricbret
Oct 21, 2018Guide
Netgear USB Control Center and Mac OS Mojave 10.14
Configuration:
Internet connection through Netgear Nighthawk r7000 A1900 Smart Wifi Router
USB connection from Brother HL-l2300D (no built-in networking) to Netgear AC1200 High Power 700mW Dual...
ricbret
Feb 01, 2019Guide
So Jeff, will this will work with dumb printers that only have a USB interface that is plugged into a Netgear extender? Do you recommend the 5.0 version, or is the 3.15 version suitable for determining it's performance?
JeffStent
Feb 02, 2019Tutor
My printer is a dumb printer. I simply plug the USB printer cable into the rear, 2.0 USB port. I believe my Handy Print software is the most recent for iOS. That is version 5.2. Works like a charm. Just be prepared for a bit of delay before the printer starts. I use this for both my iPhone, and my wife’s iPhone. We each also print from iPads
I hope that helps!
- ricbretFeb 02, 2019Guide
While I'm happy this works in your situation, after playing with this for an hour I'm pretty sure it's not addressing the point of this issue. Let me explain.
I have an HP Laser Printer in another room. It's not attached to my Macintosh. The USB cable on the printer is plugged into the USB ports on a Netgear AC1200 High Power 700mW Dual Band Wi-Fi Range Extender. Previously, the Netgear USB Control Center software allowed me to attach to that remote printer over my home network to print directly.
I believe the HandyPrint is mostly made to allow a printer attached to a Macintosh to be shared out to other computers and mobile devices. It doesn't appear to talk directly to the Extender to access its USB connected printer. I suspect it wouldn't work if the printer was similarly attached to the WiFi router (in my case a Netgear Nighthawk X4).Thanks,
-Ric
- JeffStentFeb 02, 2019Tutor
So sorry, Ric -
I have no experience with any extender. My printer is plugged directly into the router USB port. Works fine for multiple iOS devices.
Perhaps someone else can offer guidance for the extender.
Jeff
Thanks Jeff. My config still works fine with the PC in my den as well (right next to my Mac and running the PC version of the Netgear Control Center Software) so I'm absolutely sure this is a problem that will be solved by a new version of the Mac version of the Netgear Control Center Software that is compatible with the latest builds of OSX. I know they're working on it, but it's obviously not a priority for whomever it is assigned to.
