ricbret
Oct 20, 2018Guide
Netgear USB Control Center and Mac OS Mojave 10.14
Configuration:
Internet connection through Netgear Nighthawk r7000 A1900 Smart Wifi Router
USB connection from Brother HL-l2300D (no built-in networking) to Netgear AC1200 High Power 700mW Dual...
schumaku
Mar 08, 2019Guru - Experienced User
Understand Netgear is phasing out this feature - at least it's absence of the ReadyShare USB Print feature from the bleeding edge RAX80 (AX8) and RAX120 (AX12) does confirm this impression. Is this another dead end ChristineT Christian_R ? Fixing this should take days, not more than half a year. If this is the"new Netgear" than good night.
ricbret
Mar 08, 2019Guide
That would be disappointing and a very good reason to go with a different manufacturer. Developers need to budget for system-change-related updates to their utilites, otherwise they're just planning for the product to become obsolete. Rewarding such planning by buying another product from them is the worst message we can send as consumers.
And yes, as someone with decades of software development under his belt, I can confirm that a reasonably skilled OSX developer should be able to do such an update in days, not months.
- jimsiler21Mar 08, 2019Aspirant
Just got off the phone with Netgear "support". Suffice it to say I will not be buying any more Netgear products. As to the software, send me and NDA and, after I execute it, the source. I'd rather do that than ever repeat the experience I just had. Beyond the general and truly grotesque incompetence (it took my 10 minutes on the phone with a supervisor to convince him to find out what the problem was or even let me tell him) there was the "it's out of warranty" spiel.
I don't know what's going on in Netgear land but it's clearly not good.
I've finally decided to run everything in via pfSense and just use ORBI as an AP. At least then I can control what needs to be controlled and fix things if they break. I don't envy anyone without deep technical know how who face a Netgear problem.- schumakuMar 11, 2019Guru - Experienced User
The list of g. i. (love that wording) can be exceeded to many other - mostly consumer - products. Plenty of issues carried forward to the latest AX routers - without the slightest enhancements to complete product series. Christian_R (can no longer find @ChristineT why ever, probably a SaaS issue). And qualified criticism is honoured by ignorance on all channels - wonder how we're supposed to help the loyal customer.
- jimsiler21Mar 24, 2019Aspirant
To make things ever so much nore fun, there isnoobvious way to remove the software from my macbook or even stop it from autostarting. And as far as warranty Netgear has claimed that it is not bound by Maine state law regarding implied warranties.
===== a reply from netgear =====You can refer to this articles that the Netgear Devices Has Only 1 Year of Hardware warranty and 90 of technical support from the date of purcase. and for our newly implemented that the orbi devices comes with 1 year off technical support from the date of purchase. however your devices is already beyond that entitlements/warranty.
and this warraty is implemented to the hole North America in all states.===== end of netgear reply =====
I also don't appreciate them refering to North America as a "hole" ;-)
Much easier than fighting with them is to find and contact reputable reviewers such as wirecutter.com that have given high marks (in this case highest rating) and let them know what level of support their readers can expect when facing problems.
- DexterJBJan 20, 2020NETGEAR Moderator
Hi all, a new version is available for download on the link below.
Dexter
- ricbretJan 21, 2020Guide
Got direct mail that this had been fixed and the fix was publicly available.
An hour after I started attempting to get it to work, I'm convinced this is as broken as the previous release.On install the app is noted as unsigned and the developer is not registered in the installer or application. macOS Catalina is more stringent about this, but I used all the standard bypasses (comand-click the icon and choose Open from the pop-up menu to bypass security issues, etc.
Finally getting it installed I'm greeted with the same damn Installation is incomplete message from before. The app launches, but is totally unresponsive. I'll include images of the relevant messages.
Oh, also, successive attempts at installing added multiple login items for my user profile. Image included (after I deleted four or so of them from successive attempts at installing).Of course this system is so lame I'm limited to one image upload, so I'll have to put them all into a single image.
I'm glad I've already given up on this app and am planning on replacing my Netgear equipement later this year. Shame, I used to be so proud of my router choice, now I'm pretty much done with this company.
