JosHoeben
Nov 15, 2020Guide
Netgear USB Control Center MacOS Big Sur
Dear community, After updating my iMac to 11.0.1 (Big Sur) the Netgear USB control center fails. It spits out the following message when starting up the application: "Installation of the control...
JosHoeben
Nov 23, 2020Guide
Contacted Netgear for support, this is their reply so far:
Going back to the reason for your contact, as I understand, the Netgear USB Control Center (v3.1) does not work after you have installed macOS 11.0.1 (Big Sur). Let me inform the right department about your concern. Please give me 24-48 hours. I will immediately update you once I receive a response from them.
- soul4tntDec 01, 2020Aspirant
...and probably never heard back from support. lol
I doubt they will care about this issue, to be honest.
JosHoeben wrote:Contacted Netgear for support, this is their reply so far:
- JosHoebenDec 01, 2020GuideLet's see, just asked them for an update...
- mackerman4582Dec 03, 2020Tutor
i would love to know the answer to this as well.
