JosHoeben
Nov 15, 2020Guide
Netgear USB Control Center MacOS Big Sur
Dear community, After updating my iMac to 11.0.1 (Big Sur) the Netgear USB control center fails. It spits out the following message when starting up the application: "Installation of the control...
JosHoeben
Nov 23, 2020Guide
Contacted Netgear for support, this is their reply so far:
Going back to the reason for your contact, as I understand, the Netgear USB Control Center (v3.1) does not work after you have installed macOS 11.0.1 (Big Sur). Let me inform the right department about your concern. Please give me 24-48 hours. I will immediately update you once I receive a response from them.
soul4tnt
Dec 01, 2020Aspirant
...and probably never heard back from support. lol
I doubt they will care about this issue, to be honest.
JosHoeben wrote:Contacted Netgear for support, this is their reply so far:
- JosHoebenDec 01, 2020GuideLet's see, just asked them for an update...
- mackerman4582Dec 03, 2020Tutor
i would love to know the answer to this as well.
- JosHoebenDec 08, 2020GuideWas in contact with them a couple of times and got an update from their expert today.
Update vom NETGEAR
Hi Jos,
Good day!
This is ##### from Netgear. This is just to update you about the compatibility issue of the USB print utility on BigSurf OS
Firmware has been created that should solve the problem with compatibility.
For the moment the firmware is in the phase of various tests by our engineers
There is no time provided when it will be release in the Netgear site. It will be officially released on our site once it is fully verified.
I will just leave your case open here so we can still have an update .
