JosHoeben
Nov 15, 2020Guide
Netgear USB Control Center MacOS Big Sur
Dear community, After updating my iMac to 11.0.1 (Big Sur) the Netgear USB control center fails. It spits out the following message when starting up the application: "Installation of the control...
JosHoeben
Dec 08, 2020Guide
Was in contact with them a couple of times and got an update from their expert today.
Update vom NETGEAR
Hi Jos,
Good day!
This is ##### from Netgear. This is just to update you about the compatibility issue of the USB print utility on BigSurf OS
Firmware has been created that should solve the problem with compatibility.
For the moment the firmware is in the phase of various tests by our engineers
There is no time provided when it will be release in the Netgear site. It will be officially released on our site once it is fully verified.
I will just leave your case open here so we can still have an update .
Update vom NETGEAR
Hi Jos,
Good day!
soul4tnt
Dec 08, 2020Aspirant
Thanks for the update Jos!
Update vom NETGEAR
Hi Jos,
Good day!
- JosHoebenDec 14, 2020GuideThank you for your response . However I am not sure if there is a Beta Firmware for this to be release.
But I just check for an update on this and they are working for the firmware and hoping to be release before year ends .- ApolloDeltaJan 20, 2021Aspirant
If it does not work with Big Sur, can we have our money back?
