rlb41
Sep 27, 2016Aspirant
netgear wnr614 "block services" is not working
Hi, We (four) are sharing 2 Mbps internet bandwidth using NETGEAR wnr614 router in our house, one of my brother start to download torrents other three are not even able to browse, so i have tried...
- Sep 27, 2016
Unfortunately, the WNR614 does not support QoS, so there's no way to limit the bandwidth used by your brother. You will need a different router.
rlb41
TheEther you are right, with the app you refered shows more than 50 ports randomly opening and closing.
port blocking is NOT the right option.
Thanks for the great support.
Is there anyway you can provide me to limiting the bandwidth of my brother's mobile or, sharing more or less
equal bandwidth ?
TheEther
Sep 27, 2016Guru
