crowne
Aug 02, 2015Follower
NetgearGenie.exe enable Autostart on Windows 8.1
I'm transtitioning to a new laptop running Windows 8.1 and I can't seem to get NetgearGenie to load automatically when I log on.
It was doing this without any issues on my previous laptop running Windows 7.
I've unchecked and checked the option in the tray "Settings / Enable Autostart"
I've tried adding a shortcut to the startup folder "shell:startup",
I've tried changing the settings on the shortcut to "Run as Administrator"
and I tried changing the compatability settings to Windows 7.
None of this seemed to work.
I am running NetgearGenie Version 2.4.12.
Does anyone have autostart working on windows 8.1?
If so did you do anything special to get the autostart working?
- DonKanoneAspirant
I´ve the same problem, at first on W7 and now on W10. Autostart with no function.
- netwrksMaster
Here's a link to other 8.1 user's. Just an FYI, Genie can have a negative impact on your network, running it on a PC. It is not required to run your router. So, if you do get it loaded, and your network starts to do weird things, (network slow down wifi disappear) close the app, and see if you network stabilizes. You can login to the router via the default router ip address (192.168.1.1) from a web browser.
https://community.netgear.com/t5/General-WiFi-Routers/NetGenie-on-windows-8-1/m-p/379073#U379073
- Mike833335007Aspirant
I too have the same issue. Autoload worked fine in Windows 7. Autoload does not work at all in Windows 10. I use Genie for printing from my iPad to my Samsung printer through a TrendNet printer server. Now I have to manually open Genie in order to print from my iPad; with Windows 7 I did not have to since Genie autoloaded automatically at startup without a hitch. Not a big deal, but inconvenient.
- x123Aspirant
I have same issue since updating from W7 to W8.1
will not auto start
if i manually start Genie, runs perfectly
- DexterJBNETGEAR Moderator
Hi x123,
Please make sure that the NETGEAR Genie program is set to auto start. You may refer to the steps below:
1. Press the combination of Windows key + R to open the Run command.
2. Type msconfig and press Enter.
3. Select the Startup tab.
4. Make sure that the NETGEAR Genie application is checked.
Dexter
Community Team
- DonKanoneAspirantI had contact with the technical support and they will fix that problem
...best regards- tamanacoApprentice
Still not fixed in Windows 10 with the latest release 2.4.16 - No icon shows up in the taskbar unless one starts the Genie Desktop Application.
Hi tamanaco,
I can confirm this. We are constantly working on the NETGEAR Genie program to make sure it provides the functionality that is expected of it. In the mean time, please make sure that you keep the program up to date for possible fixes.
Dexter
Community Team
- Zed273Aspirant
I too had this problem but found a fix. In this thread:
http://www.eightforums.com/performance-maintenance/11216-startup-programs-wont-start.html
There are instructions for changing your security policy to allow certain apps to run. Once I made the change, Netgear Genie would autostart (among a couple other programs I was having the same issue with).
