crowne
Aug 02, 2015Follower
NetgearGenie.exe enable Autostart on Windows 8.1
I'm transtitioning to a new laptop running Windows 8.1 and I can't seem to get NetgearGenie to load automatically when I log on. It was doing this without any issues on my previous laptop running Wi...
Mystara
Oct 12, 2015Initiate
Since this application seems to ignore it's startup call, is it possible to start the program using a Startup folder shortcut and a command line option to minimize it to tray?
I know I do not need this application for most things, it does however provide me with the ability to Air Print from my mobile devices, so it has it's uses. That is something I cannot do from the web interface.
DexterJB
Oct 12, 2015NETGEAR Moderator
Hi Mystara,
Yes, you may try adding the program shortcut to the Startup folder of Windows. As for letting it startup minimized, you can right click on the shortcut > select Properties > select the Shortcut tab > look for Run > select Minimized on the drop down menu > click Apply then OK.
Dexter
Community Team
