ripper2860
Dec 06, 2015Aspirant
Netgenie issues with WNDR3700v3
Hello -- I'm hoping y'all can help me. I have a Netgear WNDR3700v3 router w / the latest formware (V1.0.0.38_1.0.31). I am also running the latest Netgenie (2.4.16.00) as I had to upgrade for use w...
ripper2860
Update -- If I use the WEB Admin portal to reboot the router, Netgenie issues described disappear for a few minutes allowing me to enter Router Settings and Parental Controls. After a few minutes it stops working again exhibiting the issues described in the OP. Another reboot via web and it works again -- for a few minutes.
DexterJB
Dec 08, 2015NETGEAR Moderator
Hi ripper2860,
1. Have you tried using another computer/device (another computer, smartphone, tablet) with the NETGEAR Genie installed?
2. Have you tried uninstalling and re-installing the NETGEAR Genie program from the Windows 10 computer?
3. Did you upgrade the computer from Windows 8 to Windows 10?
4. Did you perform a factory reset after the router firmware update?
Dexter
Community Team
- ripper2860Dec 12, 2015Aspirant
Dexter,
Thanks. I've been rather busy and just had the opportunity to check for a repsonse. Below are your answers ...
1. Have you tried using another computer/device (another computer, smartphone, tablet) with the NETGEAR Genie installed? (On Android phone it says 'Network Connection is busy -- try again later or reboot your router'. I can try another computer, but it's Win 10, as well.)
2. Have you tried uninstalling and re-installing the NETGEAR Genie program from the Windows 10 computer? (Yes - Several times)
3. Did you upgrade the computer from Windows 8 to Windows 10? (Yes)
4. Did you perform a factory reset after the router firmware update? (No. I've done a lot of configurations changes from default. I have a lot of reserved IPs and settings for my wireless and Multimedia streaming. Anyway to save the setting and re-apply them after a reset?)
- DexterJBDec 12, 2015NETGEAR Moderator
Hi ripper2860,
I recommend installing the latest version (2.4.20) of the program and see if the issue persists. You may refer to the link below on how to backup the router configurations.
http://kb.netgear.com/app/answers/detail/a_id/24231
Dexter
Community Team
Dexter,
Thanks. I actually installed the newest update to Netgenie last night and it did not resolve my issue. I followed your link re: settings backup and was able to back, factory reset and restore my settings. I'll see if the issue persists and will report back.
Again -- thanks!!
