BONNERS74
Jun 04, 2020Initiate
Nethawk App
Hi All, my first post. Im having continued problems with my Nighthawk App. As I write this, the AX4 is sitting just to my left, switched on and providing internet to all of the house. But when i open...
Jun 04, 2020Guru - Experienced User
what modem are you connected to?
have you tried to access it from the browser?
BONNERS74
It’s plugged directly into my nbn box on the wall. It works perfectly. And I used to be able to log in to the app no problem. Recently it started doing this. Last time it happened I rebooted router and app worked.
- michaelkenwardJun 05, 2020Guru - Experienced User
BONNERS74 wrote:
It’s plugged directly into my nbn box on the wall.What is that nbn box on the wall?
NBN is a wonder to behold. No two ISPs seem to have the same implementation or equipment.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
