BONNERS74
Jun 04, 2020Initiate
Nethawk App
Hi All, my first post. Im having continued problems with my Nighthawk App. As I write this, the AX4 is sitting just to my left, switched on and providing internet to all of the house. But when i open...
BONNERS74
It’s plugged directly into my nbn box on the wall. It works perfectly. And I used to be able to log in to the app no problem. Recently it started doing this. Last time it happened I rebooted router and app worked.
michaelkenward
Jun 05, 2020Guru - Experienced User
What is that nbn box on the wall?
NBN is a wonder to behold. No two ISPs seem to have the same implementation or equipment.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
