AnasaziDan
Jul 30, 2021Aspirant
NetWare app reports that my modem is not supported
My router is an ASUS RT – AC66U and I run DD-WRT software on that platform. The NETWARE app on my iPhone 7 reports that my router is not supported. On my PC I am running Windows 10 latest version. I...
Jul 30, 2021Guru - Experienced User
ALso if you run DD-WRT on your router, then you should check out DD-WRTs web page and support forums as well for there FW products.
Good Luck.
AnasaziDan wrote:My router is an ASUS RT – AC66U and I run DD-WRT software on that platform. The NETWARE app on my iPhone 7 reports that my router is not supported. On my PC I am running Windows 10 latest version. In Is there a remedy for support for my router/software configuration?
