a376
Apr 18, 2021Follower
New Device keeps connecting to my network
My network is password protected and I keep receiving a notification from my Nighthawk app that a device has joined my network. When I go to the app, there is no new device listed under my connected devices, just my own devices, however this happened again today and this time it showed up under my devices. I turned off the toggle and then it was removed. What is this device and should I be concerned? I just changed my password yesterday. The unknown device is the DEV one.
a376 wrote:
My network is password protected and I keep receiving a notification from my Nighthawk app ...
What does it say?
It can be hard to pin down what these things. They may well be one of your devices throwing in a second connection. (It has happened.)
You can try to pin it down by working out who made the thing. Grab the MAC address and throw it into a search.
Start with this tool:
MAC Address Lookup/Find Tool for Windows
- I’m having the same exact issue, and the device name does not have a legitimate MAC address. It shows up in the notification pane in a “DEV- XX:YY:ZZ” format.
Neither user interface (Netgear app or 192.168.1.1) lists any unknown devices….
