patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
Today I was forced to upgrade to the new Nighthawk Ap...
patsch
Apr 18, 2019Tutor
On a related note....I tried to factory reset the AC750 router to get rid of the parental controls alltogether - after 10 minutes the amber light is still blinking...I thought that factory reset (holding the button on the back for 5 seconds) should initiate a reboot ?
- michaelkenwardApr 20, 2019Guru - Experienced User
patsch wrote:
On a related note....I tried to factory reset the AC750 router to get rid of the parental controls alltogether...
What's the model number? It will be something like R6XXX.
AC750 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds.
- patschApr 26, 2019Tutor
R6020
- schumakuApr 20, 2019Guru - Experienced User
Factory reset won't disable LPC -> https://support.opendns.com/hc/en-us/articles/227987607-How-to-Enable-Disable-Live-Parental-Controls
As the LPC control is not available on the Nighthawk App (one of many shortcomings on the Nighthawk App), you have to head to the desktop (Windows or macOS) Genie versions. Head to https://www.netgear.com/lpc and scroll down for the downloads.
patsch wrote:
... - after 10 minutes the amber light is still blinking...I thought that factory reset (holding the button on the back for 5 seconds) should initiate a reboot ?
Reads like corrupted firmware, requiring recovery. Same after power-off and power-on?
