patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
 As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
 Today I was forced to upgrade to the new Nighthawk Ap...
michaelkenward
Apr 20, 2019Guru - Experienced User
patsch wrote:
On a related note....I tried to factory reset the AC750 router to get rid of the parental controls alltogether...
What's the model number? It will be something like R6XXX.
AC750 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds.
patsch
Apr 26, 2019Tutor
R6020
