patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
 As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
 Today I was forced to upgrade to the new Nighthawk Ap...
codyag
Apr 30, 2019Initiate
Same problem here, Disney Circle is not working either.  Netgear, please fix this ASAP!
schumaku
Apr 30, 2019Guru - Experienced User
A little bit off-topic - Netgear does fail again to make things clear. Why on earth don't they use the term "Circle" or "Circle by Disney" also on the App? No, they replace it (apparently) by a tile named "Parental Control" and confuse both the Live Parental Control (OpenDNS based) as in place on many Netgear routers.
Back to Circle by Disney issue - Netgear has published yet another marketing video https://community.netgear.com/t5/Nighthawk-App/Manage-Your-Network-amp-Get-More-Out-Of-Your-WiFi-With-The/m-p/1744185#M9451 stating:
"From the app dashboard, you have easy access to these features:
• Device List — Monitor the devices connected to your network and pause the Internet to any device.
• Internet Speed Test — Check the broadband speeds from your service provider.
• WiFi Settings — Update your router’s firmware and personalize your network name and password.
• Guest Networks — Set up separate WiFi access for guests.
• Smart Parental Controls — Easily manage content & time online with Circle® with Disney.
• Remote Management — Easily monitor your home network anytime, anywhere."
Yet another marketing lie, isn't it Dustin_V  ?
