patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
Today I was forced to upgrade to the new Nighthawk Ap...
lauranda
Jun 27, 2019Tutor
It appears to be both. Now parental Controls can no longer be enabled in router login page even with the old firmware. Ugh
schumaku
Jun 28, 2019Guru - Experienced User
Hm, there as never a control to enable it on the Web UI - it always redirected to the NTGR LPC Web page AFAIK.
You must use the Genie desktop program on Windows or MacOS to enable OpenDNS based LPC -> How do I configure Live Parental Controls on my NETGEAR router? Once enabled, most of the specific administration is done on the https://netgear.opendns.com/ Web page.
- laurandaJun 29, 2019Tutor
Today I found I had to re-activate and setup OpenDNS - I was not able to do this from the web interface because it directs you to Circle Disne, but setup worked in the older version of Genie. Yaay! I can now enable/disable parental controls (see image) from the routerlogin.net web interface from my phone. Note: Old versions of Genie are available from APKPure app store!
